1998 GMC Jimmy Fuel Pump location
AMNPWADE
Engine Performance problem
1998 GMC Jimmy 6 cyl Four Wheel Drive Automatic
I know this must be a silly ? but my sons truck is in another state so I cant look at it so I need help. Typically in a 98 GMC Jimmy SLS where is the fuel pump in the tank or out?
May 11, 2008 at 3:49 PM
  • 75,988 POSTS
The fuel pump is in the fuel tank. To confirm its the fuel pump you need to check the fuel pressure -the normal reading for this pump is 60-66psi
May 11, 2008 at 10:04 PM
