Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Jimmy
Drivetrain
Bearing Hub
Replace/Remove
1998 GMC Jimmy front wheel bearing hub
1998 GMC JIMMY
14,500 MILES • 6 CYL • 4WD • AUTOMATIC
TOMDISH
MEMBER
1 POST
changed both front wheel hubs jan2007 front pass side went bad feb 2008 changed again now its bad again what other problem can i check for
Sep 4, 2008 at 10:02 AM
SWILLIAMS
Experienced Mechanic
Where are you buying the hubs? Have you used an impact gun on the lug nuts or the axle nut? They can damage the bearings if you rattle them a lot.
Sep 6, 2008 at 7:06 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
