1998 GMC Jimmy front wheel bearing hub
1998 GMC JIMMY
14,500 MILES • 6 CYL • 4WD • AUTOMATIC
TOMDISH
changed both front wheel hubs jan2007 front pass side went bad feb 2008 changed again now its bad again what other problem can i check for
Sep 4, 2008 at 5:02 PM
SWILLIAMS
  • 597 POSTS
Where are you buying the hubs? Have you used an impact gun on the lug nuts or the axle nut? They can damage the bearings if you rattle them a lot.
Sep 6, 2008 at 2:06 PM
