1998 GMC Jimmy engine light
124,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANGELO DELLECAVE
very cold this morning. warmed up car for 20 minutes. got in & it was idling rough & engine light on. started driving & engine settled but engine light started flashing. at stop light the flashing stopped but it started idling rough again. i had a problem similar to that before & it turned out to be o2 sensors so i changed them out & it ran fine. my concern is that the light is flashing which it didn't do that before. i checked oil to look for a cracked head & it seemed fine although there was a little odor. also fuel odor while driving. i guess my question is could the o2 sensors have gone bad again because of the cold?
Feb 10, 2008 at 10:55 PM
  • 75,988 POSTS
You need to pull the OBD2 code/s from the PCM to determine exactly what's wrong and comeback with the code/s for us to help you.
Feb 12, 2008 at 9:32 PM
