1998 GMC Jimmy EGR Valve
1998 GMC JIMMY
240,000 MILES • 6 CYL • 4WD • AUTOMATIC
BANDRUSHKO
I was told by a mechanic friend that the problem I am having is due to the EGR valve. He had used the scope and it read that the valve is the problem. It idles roughly - wants to stall bellow 2000rpm, but once it gets going it's fine. It's $250 to replace and I am concerned that if I replace it and the problem still exists, I won't be able to return the part - it may be something else. I did mget one from the wreckers but it did the same thing. If it is this, are there sites where prices are better? Thanks
Sep 30, 2010 at 6:56 PM
Why don't you try cleaning it up and see what happens and also the idle air control valve , PCV valve and test the throttle position sensor
Sep 30, 2010 at 9:05 PM
