1998 GMC Jimmy 4WD will not engage
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
SCL
We have replaced the solenoid motor, re-soldered the contacts on the push buttons and we cannot get our 4WD to work. We hear clicking noises when you press the buttons and the light blinks but will not stay on. Is this the actuator under the battery tray, or the circuit board on the passenger side, or something completely different?
Dec 27, 2007 at 1:53 PM
M KRUK
the noise could be the actuator . check to see if the transfer case motor is working. good luck
Dec 28, 2007 at 1:40 AM
