1997 GMC Jimmy stripped starter mount bolt holes
1997 GMC JIMMY
MIKEGOODNOUGH
Engine Mechanical problem
1997 GMC Jimmy 6 cyl Two Wheel Drive Automatic
is it possible to rethread the mount hole that secures the starter to engine so it can line up with the flywheel
Mar 7, 2010 at 2:30 PM
HMAC300
  • 48,601 POSTS
if you haven't screwed the holes up to much you cna try a heli coil If not, good luck
Mar 10, 2010 at 9:27 AM
