1997 GMC Jimmy Sputtering
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
GREENY4704
My Jimmy shut off on me one day on my way to work didn't act weird or anything just shut off. I can get it to start every now and then and it will idle perfect till i shut it off. When i start to accelerate it starts to sputter and will only get to like 1500 rpm's. What can i try?
Jul 6, 2010 at 12:25 PM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 6, 2010 at 3:16 PM
