1997 GMC Jimmy runs rough
130,000 MILES • 6 CYL • FWD • AUTOMATIC
GREG5
at start up the engine will sometimes turn a few times before starting and run rough. it shakes at a stop, once on the freeway it runs good.
I have been told the following
engine light does come on when it gets warmed up
i was told that my iec valve may need to replaced
also someone told me my timing belt could be going out
can you please give me the correct steps to take
thank you sirs
greg5
Dec 4, 2008 at 12:11 AM
MMPRINCE4000
  • 8,548 POSTS
Take the car to any autoparts store and get the codes read.
It could be the IAC, but could also be coolant temp. or any number of sensors.
If this is the 3.8 or 4.3 it does not have a timing belt.
Dec 4, 2008 at 1:10 AM
