1997 GMC Jimmy No dash lights; wont start
1997 GMC JIMMY
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
KIMMIEBLING
Last night came out and my car would not start. There were no dash lights, althought the headlights and radio were working. When I turned the key it seemed like it wanted to start. Tried this several times and then finally it started. It then drove fine and when I got home turned it off and tried to start it again and the same thing. HELP!!!
Sep 30, 2009 at 2:26 AM
JDL
  • 16,098 POSTS
If the starter won't crank, and no dash lites, I'd check the feed to and from the ignition switch. Also make sure the battery has a full charge and the connections are good.
Sep 30, 2009 at 3:03 AM
