1997 GMC Jimmy high oil pressure
15,000 MILES • 6 CYL • 4WD • AUTOMATIC
RJCNOV11
pressure gage reads to the high side and i have a check eng light on performance is slugish
Feb 23, 2010 at 12:48 AM
HMAC300
  • 48,601 POSTS
if you don't put a emchanical oil gugae on to check you have just a general idea on it. 50-60p.si. at 200 or so rpm is normal. and 20 p.s.i. at idle is ok too. You need to get the codes read to see where the problem is for the service engine light.
Feb 23, 2010 at 3:44 AM
