1997 GMC Jimmy fuel pressure regulator
1997 GMC JIMMY
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
KICKSTANDER
location of pressure regulator on throttle body 4.3 vortec
Nov 17, 2008 at 8:45 AM
RHALL77
  • 3,361 POSTS
i think it is located in the lower intake, what kind of problem are you haveing
Nov 18, 2008 at 10:13 AM
KICKSTANDER
I believe it might have a leak , or possibly a leak in the injector's plastic lines. It's hard to start after it's been sitting awhile. With a shot of ether or continuous cranking it'll start and run fine all day. It has a new fuel pump, filter, cap, rotor, ignition mod, wires, o2 sensors. Maybe the pump is bad also. ?
Nov 18, 2008 at 11:33 AM
