Replacing Fuel lines
1997 GMC JIMMY
176,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKEWWW
I am replacing the rusty fuel supply & return lines on my 97 Jimmy. Are both lines under pressure or just the supply line? I was using a high pressure rubber fuel line for the job but it is very expensive. I wanted to know if I could use a regular low pressure fuel line (much cheaper) for the return to the tank.
Thanks
Jun 3, 2009 at 9:29 PM
2CARPRO JACK
  • 11,533 POSTS
I wouldnt suggest it.The entire system is under more pressure than regular fuel line can handle.I suggest getting a cheap tubing bender, a flaring tool and some double flare connectors and using metal line.
Jun 4, 2009 at 12:44 AM
SEANJEFF
I have a 96 Jimmy and the fuel line is leaking... do I have to drop the fuel tank in order to repair the leak with nylon gas line? It is leaking on the line below the drivers door.
Sep 2, 2019 at 5:19 AM (Merged)
You don't have to drop the fuel tank Cut the line right there and splice in make sure the fuel hose will hold the specified fuel pressure
COLBYCINN
How do I replace the fuel line on the 1993 GMC Jimmy?
Sep 2, 2019 at 5:20 AM (Merged)
INTERNETMECHANIC
  • 700 POSTS
Hi, some of these procedures, you need to use your own initiative. If it is a steel line, the autostore probably sells what you need. You may need a tubing bender to put the proper bends in the new line. Use the old line as a template for the bends. There is a safety issue with fuel lines, the responsibility is yours.
