1997 GMC Jimmy engine not reaching operating temp
BRIAN R NUTLEY
Engine Cooling problem
1997 GMC Jimmy Four Wheel Drive Automatic
Most likely the thermostat has stuck in the open position
(luckily). I know where it is could you tell me the R&R proceedure. Removing the throttle body assembly sort of scares me.
Dec 15, 2009 at 5:36 AM
JDL
  • 16,098 POSTS
Welcome to the forum, You don't take the throttle-body off according to my info. It does say to take bracket loose from throttle-body, just a couple of nuts, then move the bracket. Take out the bolts for thermostat housing.
https://images.2carpros.com/forum/automotive_pictures/170934_throttlebody_bracket_1.jpg
Dec 16, 2009 at 6:42 AM
