1997 GMC Jimmy compression check help
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
96REALWE
  • 39 POSTS
I just had the heads on this 97 GMC Jimmy 4X4, Auto,4.3 vortex GM V6 machined, at this point the intake and exhaust manifolds are on and I would like to run a compression check before I put it all the way back together, but I have no power when I connect the battery, the battery shows 12.35 volts, on the positive side there is a thinner wire that connects with an eyelet that evidently needs to connect some where to have power to the starter. I can trace the negative to cable to the block and has continuity, the positive cable traces down to the starter. Also I have no lights or dash lights when I turn the key any ideas
Oct 4, 2010 at 6:12 PM
  • 75,988 POSTS
That thinner wire goes to the fusible link
Oct 4, 2010 at 10:27 PM
96REALWE
  • 39 POSTS
Hi Raz
Thanks for the response. where is the fusible link? the wire from the battery is only 10" with an eyelet connector
Oct 5, 2010 at 11:47 AM
  • 75,988 POSTS
Is that wire colored black if so try tracing the battery positive cable to the starter motor-also check the starter if it has additional wires on the starter battery terminal-the links could be here too
Oct 5, 2010 at 1:06 PM
96REALWE
  • 39 POSTS
had to hook up alternator to complete circuit
Thanks
Oct 7, 2010 at 4:07 AM
