1997 GMC Jimmy Can't control fan speed after been operating
1997 GMC JIMMY
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
HIGHWAYS
After running my fan for a hour or so, when I turn the fan speed down it works at that setting, but when I return the fan speed to maximum I have nothing. For me to control the inside temperature I have to dial down the manual temperature rather than reduce the fan speed. I have had the fan motor replaced twice with no luck.
Apr 14, 2009 at 10:42 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Fing the resistor and test it, it's on the a/c heater box near the fan.
ELECTRICAL TROUBLE SHOOTING BLOWER MOTOR WILL NOT RUN Check fuses. Turn ignition switch to RUN position. Check for voltage at function control switch. Switch blower switch to HI position. Check for voltage at switch and at high-speed blower relay. Ground blower motor with ignition switch in RUN position. If blower operates, motor is okay. BLOWER DOES NOT OPERATE IN HI Check for voltage at high-speed blower relay with ignition switch in RUN position and blower switch in HI position. If voltage is not present, check for voltage at blower switch. BLOWER OPERATES ONLY IN HI Check blower resistors for open condition. Check blower switch for voltage at each position. Resistor is at right rear of engine compartment on blower module.
Apr 14, 2009 at 2:23 PM
HIGHWAYS
Thanks Merlin
Apr 14, 2009 at 3:21 PM
MERLIN2021
  • 17,250 POSTS
Let me know what happens.
Apr 14, 2009 at 3:24 PM
HIGHWAYS
Will do, can't check it till Friday, will let you know on Monday
Apr 14, 2009 at 3:52 PM
MERLIN2021
  • 17,250 POSTS
10-4
Apr 15, 2009 at 3:29 PM
