1997 GMC Jimmy backfire
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
CSHEESE
What is causing my Jimmy to backfire and hesitate to take off? It only occurs sometimes. What do I need to do? Is it a tuneup problem or fuel?
Feb 10, 2010 at 10:40 PM
  • 75,988 POSTS
Check and test the following below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Feb 10, 2010 at 10:43 PM
