1997 GMC Jimmy antifreeze leaking from back of engine
1997 GMC JIMMY
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
BABYEBK1
i noticed that i had a minor leak of antifreeze coming from the back of the engine on the ground there are no visible leaks on any hoses, or the pump , or the radiator so i am wondering where the leak could be occuring hank u for ur help
Jan 27, 2008 at 2:54 AM
Its coming from a leaking freeze plug-To access it you have to drop tne transmission
Jan 27, 2008 at 3:52 AM
BABYEBK1
i also noticed thatit was very wet by the ignition section of the engine someone mentioned that it might be the inner manifold gasket might be leaking because there was wetness by the engine by the igntion section
Jan 27, 2008 at 4:02 AM
MASTERTECHTIM
  • 4,750 POSTS
i was going to ask if you looked above the transmission bell housing to see if you have antifreeze there. those lower intake gaskets can leak antifreeze out the back of intake making it seem like its coming from trans area.
Jan 27, 2008 at 4:05 AM
BABYEBK1
yes i did find it in the beginning of the transmission near the back of the engine
Jan 27, 2008 at 4:10 AM
MASTERTECHTIM
  • 4,750 POSTS
replace the lower intake gasket
Jan 27, 2008 at 4:11 AM
