I have recently replaced the fuel pump and the vehicle was running fine and then the cpi went bad and so I replaced it as well and put new plugs in and went to start the jimmy and it wouldn't start, there is no spark from the ignition coil, I know I need to check the coil, but I was cleaning the intake with spray intake cleaner while it was apart and some spattered on the distributor and I wonder if that would cause it, even though its a closed component, any ideas, it sat for 2 months with out running and had spark when parked, so something went wrong while it was just sitting there.
SPONSORED LINKS
Friday, November 27th, 2009 AT 9:23 PM
