1996 GMC Jimmy Hatch entry
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
I95CUSTOMS
My GMC Jimmy has a push button entry with a keyhole as well. When you push the button on the tailgate, it releases the glass and then you reach in to open the tailgate. Lately, the push button has stopped working and I can't make entry at all!!!! If a part has gone bad inside the tailgate how do i get it open manually?
May 21, 2008 at 1:06 PM
MASTERTECHTIM
  • 4,750 POSTS
if you cant get it open with the kley then you will have to remove the panel on the hatch from inside to gain access
May 21, 2008 at 11:45 PM
I95CUSTOMS
How do I get the panel off? I cannot get to all the clips and screws since it's in the closed position.
May 22, 2008 at 4:41 AM
MASTERTECHTIM
  • 4,750 POSTS
you will have to break it off. i ge them open by pulling real hard in the center,top where he latch is and can get it open far enough to open it with a screwdriver.
May 22, 2008 at 11:06 PM
MEDIC MAY
i was told to check the fuse i think its ecc
Dec 6, 2008 at 1:53 AM
