1996 GMC Jimmy Fuel pump wons't stop running
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
PMATCHETT
My fuel pump on my 96 GMC stays running even after I turn the key off, it keeps killing the batteriy. what could be causing this and what should I check first? I just had the pump tested and it was fine with the fuel pressure, it also runs fine and seems to not have a problem when driving?
Dec 15, 2009 at 11:57 PM
JDL
  • 16,098 POSTS
Welcome to the forum, check the oil pressure switch in the fuel pump circuit. My info showed the switch is located behind the distributor.
Dec 16, 2009 at 6:07 AM
