I have a 1996 GMC Jimmy that was bought used over a year ago. It is leaking coolant from about center area on the passenger side of the engine. I can not see to be sure but assume that it may be a bad freeze plug. What is the approximate amount of costs for this type of repair? Or could it be another leaking problem? I do not think it is a gasket as I have used stop leak and that has not stopped the problem. The coolant seems to leak out quite a bit when the engine runs but stops after it is turned off. Thank you for any info you can give me as to possible estimate of repairs.
Aug 28, 2008 at 8:54 PM
