1996 GMC Jimmy electrical problem
232,000 MILES • 6 CYL • 4WD • AUTOMATIC
RONBO.1
When I put the headlights on the radio clock light and the shift light dims out and the fuel pump gets noisier and also the battery cable sparks a little when I hook up the battery.What can it be? Thank You.
May 1, 2009 at 3:02 AM
JDL
  • 16,098 POSTS
Hello, I'd start by checking the charging system. If you have a digital multimeter you can check alternator output, engine running. Make sure the battery has a full charge, cables/wires clean and tight on both ends.
There is an allumination fuse in the fuse box for the dash lites, check for available voltage, lites on, engine running.
May 1, 2009 at 3:36 AM
