As a common acceptance, I've relented to the fact that these doors are heavy, and have a tendency to sag or drop. I understand that usually, replacing the hinge pins will rememdy the situation, however, in the mean time, I have noticed, that all of a sudden this week, the door latch itself, is remaining in the open position, and after spraying a little lubricant to try and get it to loosen up or release, it is still not working, and the door flies open at a stop or right hand turn. What can I do to quick fix, and what should I do to really fix this issue? Funds are short right now, so, I'm hoping you can offer a self fix that won't break me.
Thanks, Tymesawayston
May 24, 2008 at 10:04 AM
