1996 GMC Jimmy Brake Booster conection to Brake Pedal
1996 GMC JIMMY
CHRISG4290
Brakes problem
1996 GMC Jimmy 6 cyl Two Wheel Drive Automatic
I have a question about my 96 jimmy. How do I disconnect the brake booster push rod from my brake pedal? Also, do I need any special tools?
Sep 2, 2010 at 7:18 AM
WRENCHTECH
  • 20,761 POSTS
It should have a locking clip that you have to lift up the outer edge to clear the end of the shaft and then it will slide off to the side.
Sep 2, 2010 at 8:03 AM
