1996 GMC Jimmy
MTRON60
  • 1996 GMC JIMMY
Shakes or Wobbles problem
1996 GMC Jimmy 6 cyl Four Wheel Drive Automatic
On acceleration there is a vibration, stops when you let off gas.
Thursday, February 11th, 2010 AT 4:57 PM
TOOOMANYTOYS
  • 513 POSTS
Is it 2wd or 4wd. Check the u joints and driveshaft for damage. The driveshaft may need to be balanced
Thursday, February 11th, 2010 AT 5:09 PM
MTRON60
I already checked u-joints drive shaft does not appear to be missing and balance weights. Tires are all balanced.
It is a 4wd.
I have not checked trans-mount.
The vibration is on acceleration. Stops when I let off gas starts again when gas is applied.
Thursday, February 11th, 2010 AT 5:43 PM
HOMER1967
  • 875 POSTS
Are you sure it's not a misfire? A u-joint or drivetrain issue would not subside when you let off the gas. Jeff
Thursday, February 11th, 2010 AT 6:00 PM
MTRON60
It Idles fine and has plenty of get up and go.
It acts similar to a tire being out of balance but subsided/stops foot off gas.
Trans-mount?
Thursday, February 11th, 2010 AT 6:20 PM
HOMER1967
  • 875 POSTS
Trans mount unlikely if anything I would be leaning towards backlash in one of the rears or transfer case. Does the vehicle make any noise when putting it in gear? Especially reverse it would be a clunking type noise. Let me know.
Thursday, February 11th, 2010 AT 7:56 PM
MTRON60
I found a receipt previous owner
"vibration"
Test drove
Inspected U-joints okay Greased and installed
Removed dirt rims balanced rear tires.
At low speed 20-25 slight clunk when you let off gas.
I plan to put it up on stands Saturday to give it the once over.
Anything I can check or do to diagnose?
Thursday, February 11th, 2010 AT 8:28 PM
2 LINSEY
  • 287 POSTS
We appreciate your donation and look forward to helping you in the future. Thank you
Monday, March 1st, 2010 AT 4:03 PM
