1996 GMC Jimmy Four Wheel drive won't engage
210,000 MILES • 6 CYL • 4WD • AUTOMATIC
CADETSHARP
I have a 1996 GMC Jimmy with 210000 miles that will not engage it's four wheel drive. I have checked the vacuum and it is showing 18 in. The vacuum actuator appears to be functional and pulls the line to engage the front differential about a half inch. The transfer case and front drive shaft engage and function fine, but the differential will not engage. It was replaced with a lower mileage unit before I bought the car. How far should the actuator be moving be moving the push-pull cable to engage the differential? Where can I find a diagram for this system?
Dec 30, 2007 at 10:03 AM
WINNER
try pulling the cable with vice grips and get a friend to move the truck slowly foward and backwards while pulling on the cable if it still dosent engage the trouble is in the diff (like a slider)
good luck!
winner
Jan 12, 2008 at 2:47 PM
