1996 GMC Jimmy
DONNATHEALL
  • 1996 GMC JIMMY
1996 GMC Jimmy 6 cyl Four Wheel Drive Automatic
Where is the heater blend door actuator and how do you replace it? It, s a 1996 jimmy
Monday, October 13th, 2008 AT 4:22 PM
SWILLIAMS
  • 597 POSTS
Behind the dash on the right side of the heater plenum. R&R is simple once you see the unit.
Monday, October 13th, 2008 AT 8:01 PM
DONNATHEALL
Thanks for your help. Does the complete dash have to be removed? Thanks again.
Tuesday, October 14th, 2008 AT 8:18 AM
SWILLIAMS
  • 597 POSTS
It's easier with the dash out but it can be done without pulling the dash. Pull the trim panel and look toward the top of the plenum. You will see the control motor.
Tuesday, October 14th, 2008 AT 2:33 PM
DONNATHEALL
Thank you for your help but I have decided it's above my level of skill. Thank you again.I am sure I will need more help in the future as I am determend to learn to do it myself!
Tuesday, October 14th, 2008 AT 6:15 PM
