1996 GMC Jimmy
1996 GMC JIMMY
DUESTER01
1996 GMC Jimmy 6 cyl Four Wheel Drive Automatic
Does A 1996 GMC jimmy have A fuel pump fuse? I know that it has A fuel pump relay, I just installed A new AC DELCO pump,and with the pump came A kit wanting me to wire in A new plug,in which I did. The kit also came with A new 20 amp fuse, it states I should remove old fuse and use the new one.
Apr 1, 2009 at 8:20 PM
BLACKOP555
  • CAR REPAIR CONTRIBUTOR
  • 10,386 POSTS
yes it has a fuel pump fuse. relay just turns pump on and off and the fuse is what regulates the power. a relay could pas 1 amp to 100 amps and wont blow out and stop circuit thats why you need a fuse.
Apr 4, 2009 at 9:16 PM
