1996 GMC Jimmy
DUESTER01
  • 1996 GMC JIMMY
1996 GMC Jimmy 6 cyl Four Wheel Drive Automatic
Does A 1996 GMC jimmy have A fuel pump fuse? I know that it has A fuel pump relay, I just installed A new AC DELCO pump, and with the pump came A kit wanting me to wire in A new plug, in which I did. The kit also came with A new 20 amp fuse, it states I should remove old fuse and use the new one.
Wednesday, April 1st, 2009 AT 8:20 PM
BLACKOP555
  • 10,371 POSTS
Yes it has a fuel pump fuse. Relay just turns pump on and off and the fuse is what regulates the power. A relay could pas 1 amp to 100 amps and wont blow out and stop circuit thats why you need a fuse.
Saturday, April 4th, 2009 AT 9:16 PM
