1995 GMC Jimmy Won, t crank
WAFER64
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 214,522 MILES
Was driving Jimmy pulled over and parked and it would not crank. Checked all fuses, battery and still nothing what could it be.
Friday, April 16th, 2010 AT 8:21 AM
INTERNETMECHANIC
  • 700 POSTS
I'd have to make sure the battery has a full charge and the battery connections are clean and tight on both ends. If your saying the starter won't even crank, check the starter circuit. Do the dash lites come on, when you turn the key on? Did you try cranking in neutral? The purple wire at the starter solenoid S terminal, should be hot with the key in the crank position? Could be the starter itself? Can't tell much without some testing.
Friday, April 16th, 2010 AT 9:12 AM
WAFER64
  • 11 POSTS
Battery is fully charged have power to solenoid and gage lights come on and cycle off
Saturday, April 17th, 2010 AT 9:21 AM
INTERNETMECHANIC
  • 700 POSTS
Take the starter off and have it tested. Some of the national brand autostores will test it for you.
Saturday, April 17th, 2010 AT 9:29 AM
