Jimmy was running fine until I turned a corner, then it stated running like it was hitting on only 3 cyls, shaking a lot, running rough, putting out strong gas smell and small amount of white smoke. No water in oil. I was told by mechanic to replace fuel pump, sending unit, and filter. no change.
then to replace wires, no change. Then to disconnect catalytic conv, no change. Have replaced TPS, checked Map sensor, all to no avail. Still runs like older car with vacuum leak but I have checked the hoses too. Put a scanner on it but get no codes??? I am stumped, any suggestions what could be causing this?
Please help.
Please help.
Jul 18, 2010 at 12:42 PM
