1995 GMC Jimmy Replaced EGR Valve
1995 GMC JIMMY
216,200 MILES • 6 CYL • 4WD • AUTOMATIC
CFERRY1
  • 29 POSTS
I have just replaced the EGR Valve. Since the Diag
Codes indicated a EGR failure. The "Service Engine Soon" light has now disappeared. My question is that after installing the new EGR Valve, I hear a loud vacuum (air hissing ) noise coming from near the EGR valve. I do not recall this loud Air Noise from the Engine compartment. This may be normal ?
Could you provide some suggestions ?
Thanks
Jan 9, 2009 at 10:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
No, this is not normal.
It sounds like you have knocked a vacuum line loose. The EGR valve operates directly with the manifold vacuum so I suggest checking the hoses around the installation area of the EGR valve. Ensure all hoses are tight and free of any damage that will cause leaks.
Post your results and I will follow up.
Hope this helps..
Thanks for using 2carpros.com!
Jan 9, 2009 at 10:48 AM
