1995 GMC Jimmy Radiator
ERICCROLL
My radiator is leaking, and I am prepared to try Bar's Leak, but I am having difficulty determining where the drain plug is. I have removed the splash guard, but it is still not apparent to me.
If flushing and Bar's Leak doesn't work, I will have to change the radiator, and any hints that you could provide me before I get in there would be a great help.
Thank you very much.
Oct 21, 2007 at 11:21 AM
BLACKOP555
  • 10,386 POSTS
the drain petcock should be on the bottom left hand side of the radiator just turn it to let out hte coolant. i wouldnt use the bar radiator fix as it eventually will wear out. i would just replace the radiator. mainly i would because if it wore out there it will wear out somewhere else.
Oct 21, 2007 at 12:58 PM
