1995 GMC Jimmy problem starting
165,000 MILES • 6 CYL • 4WD • AUTOMATIC
LASHANHAMPTON
after my truck sit for 13 hours or more it takes four or five turns before it will start.
Dec 30, 2007 at 10:01 PM
CLY
  • 308 POSTS
There is a drain-back valve in the fuel pump/sender assembly that is probably allowing all the fuel to drain back out of the lines. About the only way to check it is with a fuel pressure gauge hooked up while it is happening. Make sure that the fuel pressure comes up to spec and that it does it one the first key-up cycle....
Cly
Dec 30, 2007 at 10:49 PM
