1995 GMC Jimmy oil pressure switch
92,000 MILES • 6 CYL • 4WD • AUTOMATIC
AMARTINEZ148
I have diagnosed that the oil pressure switch is faulty and a replacment is required. I can not find the unit - the fuel system is MFI - where is the oil pressue switch located? Will other componenets need to be removed to access the switch?
Oct 6, 2008 at 4:45 AM
LEGITIMATE007
  • 5,121 POSTS
Under hood, center, rear engine area, below intake manifold, mounted in engine block
Oct 12, 2008 at 3:22 PM
