Ive been having problems with my '95 Jimmy cutting out and randomly dieing. we replaced the fuel pump and have put two fuel filters on it. i also just got done putting a TPS on it, but still no luck. it idles at about 1100 rps. there is also a slight knocking sound while it idles. the check engine soon light is also on, but no one around here that i know has an OBD1 scanner. what would you recommend i should do to fix the problems as cheap as possible?
Aug 27, 2010 at 3:47 PM
