1995 GMC Jimmy High Idle speed and knocking
1995 GMC JIMMY
178,000 MILES • 6 CYL • 4WD • AUTOMATIC
TRAVIS_88
Ive been having problems with my '95 Jimmy cutting out and randomly dieing. we replaced the fuel pump and have put two fuel filters on it. i also just got done putting a TPS on it, but still no luck. it idles at about 1100 rps. there is also a slight knocking sound while it idles. the check engine soon light is also on, but no one around here that i know has an OBD1 scanner. what would you recommend i should do to fix the problems as cheap as possible?
Aug 27, 2010 at 8:47 AM
WRENCHTECH
  • 20,761 POSTS
Your going to have to get those codes read before anyone will have any idea which direction to send you.
Aug 27, 2010 at 9:16 AM
