Could be the pressure regulator or the lines themselves. They both have been known to leak. With fuel on both sides I would say it is the regulator.
No vacuum line on the regulator. It gets it's vacuum directly from inside the plenum.
What I would suggest is that since you have to take the plenum down anyway you may want to drain the coolant and change out the intake manifold gaskets as well. That will remove another possible failure item. Then with the new gaskets in place and the new regulator replace the thermostat as well. It's a bit more work but worth it. Also replace the cap/rotor if it hasn't been done yet.
SPONSORED LINKS
Saturday, January 3rd, 2009 AT 4:44 PM
