Upon the onset of noticing poor fuel economy in our
1995 Jimmy, we took it to our regular Mechanic for
a Tune-up. Our Mechanic performed the Standard
Tune-up and reported that we need to replace the
CPI or Fuel Injection Assembly. The Tune-up did
little to the Fuel consumption. On 3-05-08, I replaced
the Fuel Regulator. Fuel Pressure Test on 3-07-08 reads 62 psi key on / 59 psi engine running. Intake Manifold Vacuum Test on 3-06-08 reads 16-17 inches steady at startup idle. After some acceleration, vacuum will then decrease to 13 inches with slight needle fluctuations at idle. After the previous mentioned Tune-up another Test Facility read these two codes on their scanner: P0172 and P0304.
Presently running at 11 MPG Hwy. and City.
Can you suggest on what to test next ? Try next ?
Thank you
Thank you
Mar 8, 2008 at 5:24 PM
