1995 GMC Jimmy EGR Valve
1995 GMC JIMMY
212,000 MILES • 6 CYL • 4WD • AUTOMATIC
CFERRY1
  • 29 POSTS
The latest OBD II Scan which I had performed on my 1995 GMC Jimmy revealed a EGR Valve error.
"Pintle 10 degrees out of adjustment"
Can you tell me what are the long range effects to
my Engine if I can not replace the EGR Valve
immediately and still drive the vehicle ?
Thank you
Oct 2, 2008 at 5:56 AM
SWILLIAMS
  • 597 POSTS
Higher emissions and lower fuel mileage. However you may not need to replace the EGR. You could remove it. MANUALLY clean it and then run a test cycle on it. Then reset the ECM so it relearns the system. Then see if the error still exists.
Oct 13, 2008 at 1:31 PM
