1995 GMC Jimmy Bad idle
1995 GMC JIMMY
163,000 MILES • 6 CYL • 4WD • AUTOMATIC
SIXONEFOUR
  • 6 POSTS
I have a 95 GMC Jimmy 4.3 Vortec (CPI) 4x4 with 163k miles.
Problem:
The RPMs rev between 500 and 1500. It almost feels like its choking and sometimes stalls at the bottom. It fires right back up every time. The idle spikes up and down and continues this nasty cycle. It gets better as the truck warms up.
Recently changed:
Idle Air Control Valve
Fuel Filter
Tune up (Plugs/Wires/Cap/PCV/Rotor Button)
Several people have told me it needs a new Spider Injector. Is there anything else I can rule out or check before I invest the $300 for the injector?
Any info and advice is much appreciated! Thanks!
Nov 10, 2010 at 3:02 AM
Check the fuel pressure if its within specs if okay.Test the throttle position sensor and manifold absolute pressure sensor-also look for vacuum leaks
Nov 10, 2010 at 5:31 AM
SIXONEFOUR
  • 6 POSTS
I also suspect a vaccum leak or a fuel pump problem. Is there a way to test the spider injector? I had the intake open today to find very small puddles of fuel. It was also filthy. Keep in mind it is 16 years old. Thanks for the info!
Nov 12, 2010 at 8:16 PM
SIXONEFOUR
  • 6 POSTS
I had the truck hooked up to a diagnostic machine only to tell me the MAP sensor was reading low. I replaced the MAP sensor. It helped a bit, but did not solve the problem. How can I test the fuel pressure? Can I spray the vacuum tubes and around the intake with WD40 to check for a vacuum leak? I appreciate your help.
Nov 20, 2010 at 4:43 PM
(I had the intake open today to find very small puddles of fuel.)
If the puddle is on the pax side-the FPR is leaking-if it's @ the driver's side it's the nut kit.
Nov 22, 2010 at 2:21 AM
SIXONEFOUR
  • 6 POSTS
The fuel pressure regulator is a reasonable cause for my problem. I've since replaced the MAP sensor and the TP sensor. They made minor improvement. She still idles horribly. FPR is a fairly cheap part (Under $60).
I really need to have a fuel pressure and vacuum tests done. I will probably end up taking it to a shop for those.
Any other suggestions are appreciated! Thanks again.
Jan 1, 2011 at 10:17 PM
Inspect and clean the EGR valve and see what happens
Jan 2, 2011 at 2:31 PM
SIXONEFOUR
  • 6 POSTS
I swapped the EGR valve already, but it came from a junkyard. I also replaced the gasket. Thanks for your help! Any more ideas? I'm about to put some more cash into her this month. I have a FPR on the way and debating on just buying the injector. If that doesn't fix it, it has to be the fuel pump or a vacuum leak. Almost every sensor is new. The only ones I haven't changed out are the oxygen sensors, and the ambient air temp sensor (which is vacuum related as I understand at this point). I'll definitely keep you posted. Thanks again!
Jan 3, 2011 at 5:47 PM
SIXONEFOUR
  • 6 POSTS
Put a new injector in, cleared up a lot of the high idling, better fuel economy and more power restored. It is still spiking DOWN now and sometimes stalling around 500RPM. Still have a slight misfire.
Jan 20, 2011 at 11:07 AM
SPNZZ6
Had the same problem with my 95 Jimmy. turned out to be loose bolts on the lower intake manifold causing a vacuum leak. This actually happened twice. I found it the first time when replacing the gaskets. The bolts were finger loose but I changed the gaskets anyway. about a year later I got the same symptoms back. I located the leak by spraying around the base of the lower. Upon pulling the upper I found the bolts loose again. The specs on some sites say to do a final torque of 14 ft lbs. I found one site that said to do a final torque of 30 ft lbs.which makes more sense seeing that they are 3/8 bolts. I did the 30 with some thread sealer on the bolts. Runs like new again. Hope this helps.
Nov 25, 2019 at 10:15 PM
