1995 GMC Jimmy antifreeze & soot in EGR valve?
DOEDGI
  • 1995 GMC JIMMY
1995 GMC Jimmy 6 cyl 124000 miles
Why is there antifreeze in the EGR valve? I was told that the head gasket is leaking. Could that be the problem?
Monday, April 27th, 2009 AT 3:52 PM
DOEDGI
Please send answer to my email address, thank you.
Don
Monday, April 27th, 2009 AT 3:54 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Most likely it is a blown Intake Gasket.
Monday, April 27th, 2009 AT 3:56 PM
DOEDGI
Is this a minor repair or big bucks?
Monday, April 27th, 2009 AT 8:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, The top of the engine has to come off and most of the front of the engine. So, it could run as much as $1,000. Maybe more depending on labe rate in your area.
Monday, April 27th, 2009 AT 10:01 PM
DOEDGI
When you are driving there is a sound coming from the rear end which sounds similiar to a wheel bearing that is getting worn. I was told that it is a normal sound that goes with Hyundais. Is that true or am I being fed a crock? The car has been "certified" but has this problem been addressed when they checked it over?
Tuesday, May 26th, 2009 AT 12:38 PM
CFERRY1
  • 29 POSTS
Yes, This is a common problem if the engine has over heated And / Or GM does have a defect with the Design or Manufactured Assembly placement of Intake Gasket Sealant on the corner or one side.
You may have a local repair shop look up this manufacturer suggested corrective action concerning this Intake Gasket !
It is a Medium Big job !
Tuesday, May 26th, 2009 AT 1:39 PM
OBXAUTOMEDIC
  • 3,711 POSTS
I am not sure but will check on it and let you know.
Also Please if you have other questions on other Makes and Modeld post them in the appropriate catagory.
Tuesday, May 26th, 2009 AT 8:13 PM
