1995 GMC Jimmy
ARCHER777
  • 1995 GMC JIMMY
  • 6 CYL
  • 4WD
  • 251,000 MILES
My 95 jimmy will not shift and has bad vibration if I replace the tranny will it fix the problem?
Friday, June 18th, 2010 AT 4:57 PM
HMAC300
  • 48,601 POSTS
You should really have a trans pro check your trans to see if it's bad or not. The vibration can be anything from bad u joints to broken motor/trans mounts or axle problems. You really need to have a pro look at this.
Sunday, June 20th, 2010 AT 6:29 PM
