I spoke with a mechanic who indicated the check valve on the fuel pump is a common problem with this vehicle. After reading through the forums, it looks like the fuel pump is indeed a likely suspect.
My question is. Do I need to replace only the pump and strainer or should I also replace the sender assembly as well. Where is the check valve actually located? Thanks!
SPONSORED LINKS
Thursday, January 31st, 2008 AT 12:42 PM
