1994 GMC Jimmy EGR Valve
189,000 MILES • 6 CYL • 2WD • AUTOMATIC
KATHIRENP
Our Jimmy was sputtering while I was driving it, and even more so as I started to slow down. We took it to get worked on and was told it was the EGR Valve. It was replaced and was running great for about a month. Not it is sarting to do the exact same thing. I have heard that if the battrie is not unpluged before the EGR Valve is put it will need to be replaced in a bout a month. Is this ture or what?
Mar 7, 2010 at 5:21 AM
LEGITIMATE007
  • 5,121 POSTS
I never heard that but that is rule of thumb in a mechanics work, to always remove the negative cable before doing anykind of work , I dont care if it is changing an air filter.. change your pcv valve, and the egr may just need to be cleaned.
Mar 7, 2010 at 5:28 AM
