where is the crank shaft sensor located in a 1994 GMC Jimmy?
Mar 25, 2008 at 8:29 AM
✓Experienced Mechanic
Dunno if you have one but check at the harmonic balancer/vibration damper/pulley
Mar 25, 2008 at 8:41 AM
CRYSTALANDKEVIN1
MEMBER
i have one and i bought a new one because i had a few suggestions it could be that, but i cant find the old one. i replaced the map sensor and throttle position sensor, still not that.
Mar 25, 2008 at 8:48 AM
Look on the big pulley on the bottom of the engine-I've checked it thru the eautorepair.net non was listed-try calling the dealer
