1994 GMC Jimmy blown engine
LAKERMAN
  • 1994 GMC JIMMY
  • 6 CYL
  • 4WD
  • 134,500 MILES
Water was leaking from intake manifold gasket. Mechanic replaced intake manifold gasket & thermostat. Picked up vehicle & broke down with knocking in the engine in less than 40 miles. Towed back to same shop & they said engine is no good now. What could have happened when they worked on my vehicle?
Monday, November 17th, 2008 AT 4:03 PM
RHALL77
  • 3,361 POSTS
They didnt change the oil. Check for a new filter, anti freeze got into the bearings. I would say its there fault, unless you drove it for a while with it leaking coolant
Tuesday, November 18th, 2008 AT 6:14 PM
LAKERMAN
Thanks for the feedback. They did not change the oil. I drove the Jimmy 7 miles after it started leaking coolant(thats including driving it to the repair shop).
Tuesday, November 18th, 2008 AT 6:27 PM
RHALL77
  • 3,361 POSTS
That is most likely what happend. I cant believe they didnt change the oil. Thats the most important thing to do when a engine is opened up and resealed
Wednesday, November 19th, 2008 AT 7:50 PM
