1994 GMC Jimmy '94 Jimmy has trouble starting
157,000 MILES • 6 CYL • 4WD • AUTOMATIC
CRITTBEAST
My Jimmy has a little trouble starting after sitting for a few hours.
I eventually manage to get the engine to start after a few seconds. It has new spark plugs and all.
The weird thing is, though, after I finally get it to start and I run it for a bit, it isn't that difficult to start it up within the next thirty minutes or so. So the routine goes that I try to start it up and it sputters a bit and finally gets going, albeit roughly. Then I can run it pretty well with a small rough idle. Then, if I stop and within the next thirty minutes or so try to start it up, it doesn't have that much of a problem starting up. But if I let it sit for a few hours, it has trouble again.
I talked to my uncle and he says it might need the fuel filter replaced under the idea that the clogged filter requires a little bit of coercing to get the flow going through it once more when I try to start it up.
I also noticed a small smell of gasoline when I was parking it today.
It only started recently after a slightly arduous trip through the city. Before, I had no problems starting right up, with vigor.
Jun 16, 2010 at 3:11 PM
  • 75,988 POSTS
Hi Crittbeast, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs if okay test the coolant temperature sensor, clean out the idle air control valve and EGR valve and test the throttle position sensor
Jun 16, 2010 at 6:05 PM
