Can you check for codes? What is the fuel pressure? You need a pressure gage to check pressure. What is your vin, your vehicle came with either, cpi or tbi, The fuel pressure specs are different depending. The cpi system, key on engine off spec--55 to 61, idling-- 36 to 43. The TBI system pressure around 10.
SPONSORED LINKS
Friday, January 2nd, 2009 AT 12:58 PM
